Hello everybody! My name is Andrew. Live in Russia.
I was educated in Technical university by Welding technologies and construction materials
First I Worked in refinery and chemical processing plants by welding engineer. - Designed based on specifications and standards technologies of repair and installing technological equipment, pipe lines, tanks. Made Documentation confirming the quality of the performed work.
Then i worked in inspection of welding also on refinery. I controlled and confirmed quality of work and documentation on constructions (customer supervision).
Now I started to learn English, and also want to learn technical part of language about welding in mechanical engineering, chemistry and oil processing.
If there specialists who work on it, please give me some links to specifications and standards that you use in your work.
My lang level is very low, and i trying to do without google translate so this text could be not so correct about grammar. Sorry about that
