I do apologize for my grmar. It's like texting, lol, ha, lmao. I didn't read into it, usually I am dumbing things down for those who misunderstand easily. On the other hand, if you(not you specifically) have been in this business (welding pipe), you should be able to read the question. I do apologize for my grammar. That is all on me. I figured something out, I finished my weld, thank you for all that has replied! No intentions Kent, I was trying to keep a good rep, and was typing/thinking/reading/ talking to GF at 6:45am. Thank you.
I think we have several points of misunderstanding, including "ced". Are you meaning acetylene?
Now, PWHT = Post Weld Heat Treat is performed AFTER the welding process is complete.
Many don't realize all the available processes that are included in PWHT; annealing, normalizing, tempering, heat treating for hardness, stress relieving, etc.
BUT, when you mention it is all you have to REMOVE moisture, that sounds more like PRE-HEAT and is done PRIOR to welding.
Now, to your question as close as I can currently understand it, Oxy/fuel (acet, propylene, MAPP, propane, natural gas, etc) can be used for both pre-heat and some forms of PWHT. It all depends upon what you are trying to accomplish.
It would really help if we had a bit more information: Welding Process? Material Grade? Material Thickness? Fuel type on oxy torch? Rosebud or regular torch head? Applicable Code/type of work (structural, pipe, equipment, etc)?
Any fuel /oxygen or fuel / air torch will produce the temperature needed to drive the moisture out of the steel. SIC
I greatly do apologize for my literature, as I am always in a hurry and 99% of my time I am always finding myself trying to explain to someone that doesn't comprehend what I am telling them on a daily basis.
I was finishing up 1 of the last two welds on a water pump station. We made the fit late in the day and with no over time approved I do not work for free. I flushed it out and setting up to cap the next day. Know that here on the coast the humidity is high and it being around 60-65 in the morning, I needed to pre-heat.
The next morning nobody had a answer for me or a propane heater for me to use. Normally I do not carry one because of the safety I am normally around. I was told awhile back that I could not use Oxygen/Acetylene to pre heat a weld. I could not remember why but that is all I had available to me and when I have a couple guys waiting on me I like to get busy. That is what brought me to my question. That you have answered.
The pipe is, 16" carbon steel sch 40, B31.3, Grade X42. The line is opened ended from a pump that pumps water from a creek to a lake to supply the Company with fresh water. I know it's just all water pipe and x42, but if I keep to good habits I will not ease myself to using short cuts. Thank you for the reply. Spot on as always sir! Been following this forum when I started welding 14yrs ago. No school like the old school!
Got it. Thanks for the added info even though at this point it isn't needed.
Glad we could be of any help to you.
Brent
