Hello Hanif,
Just from looking at the photos, solidification cracking seems to be a likely culprit.
Is it possible that the cracks were missed during the initial acceptance inspection?
Hydrogen Assisted Cracking, or Hydrogen Embrittlement, Cold Cracking, etc. requires three elements to form:
Hydrogen Absorbtion
Susceptible Microstructure
Tensile Stresses
Can you define the base metal type/grade and thickness, electrode classification, pre/post heat procedure and construction code used on this specific component? Have the components been installed in a manner that introduces tensile stresses?
These things may help determine the root cause, however, the repair requirements are the same - The weld or welds need to be removed and replaced in accordance with an approved repair procedure.
Determining the actual root cause can help define the extent of further inspections and repairs that need to be made.
Here's an informative video:
https://www.youtube.com/watch?v=Wjz8eh3uxkUTim
