Up Topic Welding Industry / General Welding Discussion / B31.1 Maximum fillet weld gap
- - By Rdavid3 (*) Date 12-30-2017 11:57
We are making some socket welds. The final fit up gap is 1/4" thats 1/8" on each side is this acceptable?
Thanks.
Parent - By 803056 (*****) Date 12-30-2017 21:18
Are you referring to the diametrical clearance between the ID of the socket fitting and OD of the pipe or the gap between the end of the pipe and the shoulder of the socket fitting?
Happy New Year - Al
Parent - - By tom cooper (**) Date 01-02-2018 14:27 Edited 01-02-2018 14:33
B31.1(2016) para 127.3(E) allows a maximum diametrical clearance of .080", i.e., .040" each side.
Parent - - By 803056 (*****) Date 01-02-2018 16:13
Is he asking about the diametrical clearance?
Parent - - By tom cooper (**) Date 01-02-2018 16:22
yes
Parent - - By 803056 (*****) Date 01-03-2018 00:38
Never sure when standard terminology isn't used or a sketch depicting what is being asked isn't provided.
An 1/8 inch is not only too large, but it would indicate the fitting or the pipe isn't to spec. Perhaps they are mixing materials manufactured to metric and customary dimensions? Could they have mixed the fittings (possible if they are using small diameter pipe) or something is definitely not to spec based on the dimensions of the pipe OD and the fitting ID.
The possibilities are endless when we are not provided with all the details.
Parent - - By Rdavid3 (*) Date 01-03-2018 11:26
Thanks guys, It has been noticed that the wrong size parts were sent.
Parent - By 803056 (*****) Date 01-03-2018 15:06
That makes sense.
Parent - - By Jimhughes Date 02-03-2018 19:47
Well I’m back. After a year away due to a new position with my company.
I used to be under! Well I don’t remember my profile and I could not log in under my old user name. So this is me with a new name. I don’t have anything to add to this discussion other than what has already been said.
It took me awhile to figure out the changes that AWS has implemented. I take it we have a new forum that you pay for with membership? dues? That interesting. Well I hope to add to future discussions
Jim Hughes
Parent - By 803056 (*****) Date 02-04-2018 00:59
Welcome back.
