Up Topic Welding Industry / Technical Discussions / FCAW downhill
- - By DavidP66 (*) Date 05-20-2003 17:08
just to see if im crazy. If a person is qualified to weld flux core. Tested and passed on uphill motion. They do have to retest to get qualified going downhill correct. And also it would require a PQR to test the precidure in the downhill method. All under D1.1 code.. Am i correct?
thanks
David
Parent - By bmaas1 (***) Date 05-20-2003 20:03
you are correct.
