Up Topic Welding Industry / Technical Discussions / DIN Specs.
- - By rhoople47 (**) Date 05-21-2003 12:46
Does anyone out there know the significant differences between the AWS structural codes, and the comparable DIN (German) weld standards? I know this is a very broad question, but any help would be appreciated.
Parent - - By G.S.Crisi (****) Date 05-21-2003 15:23
Just to start with, the materials designation is different.
AWS refer to materials standardized by ASTM. ASTM A-6, for example, includes a broad list of steels used for structural purposes.
DIN St 37, for example, is a widely used material for structural applications. St means "stahl" (steel) and 37 means that the minimum yield point is 37 kgf/square millimeters (roughly 3,700 bars).
Another difference is the electrode designation. AWS has its own designation whereas DIN follows ISO's one.
I let the specialists to tell you other differences.
Giovanni s. Crisi
Parent - By rhoople47 (**) Date 05-21-2003 15:41
Thanx, any info helps.
Parent - By H.Dibben (*) Date 05-21-2003 16:36
Another thing to watch for on European drawings is that the size of a fillet weld refers to the throat size, not the leg size as we use in North America.
Parent - By G.Borst Date 06-03-2003 20:23
I have Din codes
my contry is holland europa
