Up Topic Welding Industry / General Welding Discussion / Soak Time
- - By Rdavid3 (*) Date 01-24-2018 17:39
I have been instructed to use a WPS that indicates 1/2" fillet weld that has a base metal range from 3/4" to 2 1/2" in thickness that is A36 steel.  Using E7018 with a preheat of 150 degrees minimum and 550 maximum interpass. The WPS calls for a 30 minute soak time. Can some one explain this soak time as I am not familiar with it?  Thanks.
Dave.
Parent - By 803056 (*****) Date 01-25-2018 01:36
That is a question that should be directed to the person that wrote the WPS.
Parent - - By welderbrent (*****) Date 01-25-2018 14:51
Agree with Al.  Only commented to say 'INTERESTING'.
Would like to hear the end result of that one.  I can picture a couple of different possibilities but would not want to misdirect the OP.
Parent - By Rdavid3 (*) Date 01-25-2018 15:05
Thanks guys.
