Up Topic Welding Industry / General Welding Discussion / if can welding Silver by TIG process
- - By Mohamedaminkari Date 01-24-2018 20:30 Edited 01-24-2018 20:33
Hello
I have a question
if can welding Silver by TIG process؟
AWS B Ag1?
Parent - - By Lawrence (*****) Date 01-24-2018 21:16
Welcome to the Forum !!
I have done GTAW with silver brazing wire in the past.  Usually for copper to stainless backing tools or art work.  Nothing structural or code compliant.
I have not used Bag1
Keep safety in mind as Bab1 is typically 24% cadmium which may produce very toxic fumes.
What is your application?
Parent - - By Mohamedaminkari Date 01-25-2018 08:37
Thank you
I need to connect a brass valve to steel.SS316
Check the process selection
Is there another way?
Parent - By Lawrence (*****) Date 01-25-2018 12:48 Edited 01-25-2018 12:51
You need a qualified engineer to do your project planning.
The fact that you are providing so little information tells us that you must be very new to this kind of work.   There are many variables in joint design, end use, service questions, code or standard specifications you must work under, and more that must be considered before any advice can be provided.
You need more help that can be provided here unless you can share a more complete image of what you actually require.
