PWHT is usually based on the base metal thickness or the joint thickness, whichever is greater. The PWHT parameters are based on the construction code, i.e., B31.1, Section VIII, Section I, etc.
The electrode manufacturer includes PWHT when the electrode is qualified to verify it will provide the necessary mechanical properties after the PWHT listed in the manufacture's product information. However, the contractor still has to qualify the WPS using the same A number, F number, and P number as used in construction. The qualification also must include PWHT if the product requires PWHT as part of the production requirements.
