Up Topic Welding Industry / General Welding Discussion / PWHT and RT
- - By mechbright Date 02-09-2018 12:17
What should be the sequence for PWHT and Radiography, refer code requirement if any ?
Parent - By jwright650 (*****) Date 02-09-2018 14:41
What code(s) are you working to?
What material(s) are you working with?
What welding process(es) are you using?
Etc...etc...
Parent - By TerryTerzian (*) Date 02-09-2018 22:52
That is kind an odd question. I have always gone under the assumption that PWHT comes before RT.
