Up Topic Welding Industry / General Welding Discussion / Flowmeter for Oxygen and Acetylene
- - By leedvin Date 02-21-2018 15:08
Hey Guys,
Just wondering, most oxyfuel equipment do not come with flowmeters. Does this have to do with the 15psi explosion level of acetylene?
Thanks for weighing in!
Parent - By jwright650 (*****) Date 02-21-2018 22:22
No flow meters, just psi gauges to do two things: 1) High side let's you know how much product is in the tanks 2) Secondary side let's you see how to adjust the pressures for the application...ie cutting, heating, welding, etc...
Parent - By 357max (***) Date 02-23-2018 03:53
The devices are pressure regulators. They reduce and regulate the high cylinder pressure to the working / outlet pressure. The torch manufacturer's data sheet will show the flow rate and the consumption rate; at a certain outlet pressure for a certain torch nozzle or tip size.
