Up Topic Welding Industry / General Welding Discussion / welding L-80 type 1 pipe casing to 4130
- - By qit1 Date 02-23-2018 19:19
We need to develop a welding procedure for welding L-80 Type 1 casing to cone shaped for lack of a better term "end caps" of 4130 material. the pipe and cones are 13.375" x 0.375". my greatest concern is the PWHT that would be required after welding. design temperature is -50F to +250F. design code is ASME B31.4. hydro test pressure will be 5500psi, operating pressure will be 2600psi. there will also be L-80 to L-80 welds on the piece will they also require PWHT? if anyone good give me some tips on this i would be greatly appreciative or if i more information is needed please let me know. thank you
Parent - - By 803056 (*****) Date 02-24-2018 04:27
What are the ASTM or ASME material specifications? That information is required before looking in B31.4.
The design engineer is responsible for specifying the post weld heat treatment and whether CVN is required.
Parent - By qit1 Date 02-27-2018 18:34
Thank you.
