Hi, I use a special purpose machine with Gmaw mechanized welding a T joint of spud to a tank base of thickness 2mm MS sheet. I find a pin hole at the start position always when the weld overlaps the start position before completion/stopping. To be more clear the weld starts and the rotary torch welds along the joint. it again comes to the start position with some overlap and stops. The pinhole is exactly at the start position overlap. I use 1.2mm ER 70S-6 weld wire with 230 to 250A and 26 V with 90/10 ACM. Can you please suggest a solution. Thank you.
