Up Topic Welding Industry / General Welding Discussion / weld mapping and tracking B31.3 code
- - By rickyricardo31 Date 03-07-2018 20:47
is weld tracking of shoes welded to piping? B31.3 code. and where to find documentation to back this up?
Parent - By Joey (***) Date 03-08-2018 00:49
Those welds on pipe supports are not common to put in the weld log. However, you need to inspect those welds during line checking and prior to pressure test.
Parent - By 803056 (*****) Date 03-08-2018 17:40
I believe that should be addressed by your employer's quality control manual.
