Up Topic Welding Industry / Technical Discussions / P9 toP22
- - By rainbow202 (*) Date 03-09-2018 17:57 Edited 03-10-2018 09:47
hello:
Has anyone out there welded P9 to P22 ?what post weld  heat treatment (PWHT) have you used?  what happen if i choose wrong parameters for heat treatment??
thanks
Tareq
Parent - - By rainbow202 (*) Date 03-10-2018 09:35
any answer??
Parent - - By 803056 (*****) Date 03-10-2018 14:14
So, your welding a nickel alloyed steel pipe to aluminum. Interesting. Explosive welded, friction welded?
Parent - - By rainbow202 (*) Date 03-10-2018 16:49
Nooo...... my welding chromuim mo alloy steel
Parent - - By 803056 (*****) Date 03-10-2018 17:05 Edited 03-10-2018 17:11
Looking at the P-numbers listed in ASME Section IX:
P9 - steel alloyed with nickel additions, example SA-203 grade A, B, D, E, and F
P22 - aluminum alloy, example SB-210, Alloy 5052
You have me so confused! What specifications include these P9 and P22 base metals you speak of?
Parent - - By rainbow202 (*) Date 03-10-2018 17:46
ASTM A335 P9  ...... ASTM A335 P22
Parent - By 803056 (*****) Date 03-11-2018 01:11
These alloys, while similar, are noted for their differences and the need to carefully control the PWHT. What works for one does not necessarily provide the optimum response for the others.
The design engineer should be providing the specifics of the PWHT he wants the fabricator to employ.
Best I can do without writing a book.
