Up Topic Welding Industry / Technical Discussions / Al Welding
- - By Sambuddha (*) Date 03-10-2018 10:03
What precaution we should take for Al Welding of 40mm plates
Parent - By Lawrence (*****) Date 03-10-2018 11:15
I would suggest taking all of the precautions..
But seriously, you must tell us just a little bit more about your project if you want an answer.
Parent - By welderbrent (*****) Date 03-10-2018 20:53
I was going to post more sarcasm, but, like Lawrence said, we need more info.
What grade AL are the plates?
What AL electrode were you planning to use?
What is your applicable code?
What process are you planning to use?
Have you, your welders, the company, welded AL previously?
What cleaning procedures were you intending to employ?
ETC, ETC,
- By 803056 (*****) Date 03-10-2018 14:15
Use aluminum filler metal.
- - By SANNY Date 03-21-2018 18:27
Im new on this forum: QUESTION ON CERTIFIED WELDER
for
i want to certify on ALUMINUM, I get confused on what to fill out on the APPLICATION FORM
SUPPLEMENT:
CODE:
PROCESS:
FILLER METAL:
BASE METAL:
POSITION:
THICKNESS:
THANKS
Parent - - By Lawrence (*****) Date 03-21-2018 19:41
Hi Sanny,  Welcome to the Forum
I don't know what "application form" you are talking about...  You need to say more about that.
SUPPLEMENT:
CODE:  You need to tell us which code you are working to
PROCESS:  Aluminum can be welded with many processes... You must tell us which you are able to use
FILLER METAL:  This depends on the base metal and the service conditons of the thing you are welding.
BASE METAL:   You must tell us which base metal you are going to weld.
POSITION:   Aluminum can be welded in all positions with many processes... Some more easily than others.
THICKNESS:   We don't know what thickness you need to weld... You must tell us.
THANKS
Parent - By SANNY Date 03-22-2018 07:04
ON THE AWS CERTIFIED WELDER APPLICATION FORM
SUPPLEMENT: G
CODE: D1.2 (ALUMINUM)
PROCESS: GTAW
GAS: ARGON
FILLER METAL: ER4043 ( AWS/A5.10)
BASE METAL:6061 ( B209 6061-T6)
POSITION: 3G
THICKNESS: 1/8  THICKNESS
IF THIS QUALIFICATION RANGE IS CORRECT
