Up Topic Welding Industry / Technical Discussions / Another safety related question...
- - By Tom400CFI Date 05-27-2003 17:27
For those of you who read my previous post about the tank expolsion, the staff member is doing extremely well, IMO. He is at home, and most importantly, in good spirits. Thanks to those that responded to that post.
Now here is my next question: what is the standard protocol for wearign of leather PPE when welding. I do believe welding gloves are mandatory at all times, but I'm talking about the upper body leathers. Is this a personal choice? Or is there a standard regarding what type/duration welding you are doing and what you should wear? Please input. Thanks!
-Tom
Parent - By jwright650 (*****) Date 05-27-2003 18:39
I think OSHA says that the employer must provide adequate protection for it's employees concerning the processes involved and leave it up to the employer. However they will site you if there is a condition where somebody is being injured regularly and you don't fix the problem. At least that's how I was interpeting it.
The OSHA reg.1910.132 general requirements will describe to you how far the employer must go to provide PPE.
John Wright
Parent - By JTMcC (***) Date 05-27-2003 21:16
Of course it's a personal choice, up to the point that the welder is burning himself due to lack of sensible protection. There are many levels of welding protection from the green jackets to full leather jackets, most welders will wear the correct amount of protection in self defense. Not many folks want to be burned. No one I know wears personal protection against explosions. It sounds like you've been talking to lawyers, trying to put the onus on the welder? The bottom line is, using the info provided in your previous post, your company is seriously on the hook for what OSHA used to call an Immediate Threat to Life Infraction. You are lucky the man wasn't killed. You are searching the web for information on how to do the job safely AFTER almost killing someone, I would suggest you search for that info BEFORE ignorantly proceeding with a dangerous task next time. If not for the humanitarian reasons, at least to limit your liability.
JTMcC.
