Any recommendations for band saw blades that will last more than a few cuts? (93" x .032" x 3/4")
I've been burning through the saw blades at home trying to cut this 3" SS exhaust tubing(.065" wall). I slowed the saw down to 86 fpm thinking it would help, but it still ends up ripping the teeth off long sections of the blade.
I can cut it with an abrasive cutting wheel, but the saw cut is a lot nicer to fit and weld, especially when trying to cut small pie cut sections to make smooth tight radius bends from a straight section of tubing.
