Hi VR46,
I don't have a copy of D1.2 available, but in the qualification clause, there is a table of essential variables for requalification of a procedure. One of those essential variables should require requalification when changing from semi-automatic process to automatic process.
Dear sir,
I also deal with massproduction steel frame (exp: 3000 set/day) using many units if robotic welding GMAW. Operator jobs is only set the parts (put the parts in jig), so Operator are not need Welding Certified.
But, the engineer who Teach and set the parameters need to be Certified with Weling Procedures.
Best regards
