Yup, I hear you Shane, and you're right.
A good I&TP that allows for spot testing will have a rider that states, for example -
Spot RT 10%
If defects found, change to 50%
If more defects found, change to 100% (etc. etc.)
It should also include a provision that if the customer, during receipt inspection VT finds defects that indicate a lack of "thoroughness" (for lack of better words) in the Contractor's work quality / inspection, the Customer has the right to perform additional NDE to determine if the product meets the contract specs. If the Customer finds a lot of defects, hopefully their contract / I&TP will allow them to either reject or repair at the Contractor's expense. This is all too often necessary when shoddy contractors try to push off poor work with falsified inspection reports.
Each case is different, a lot depends on the end use of the products and the severity of potential in service failures, so it all boils down to the job specific I&TP.
