Up Topic Welding Industry / General Welding Discussion / Dimension of plate and pipe for welder qualification.
- - By Abdul Azeem Date 05-14-2018 20:24
Hello People,
What should be the dimension for welder qualification (Plate and Pipe) According to AWS D 1.1 and ASME Sec IX .
Please assist .
Parent - - By 803056 (*****) Date 05-17-2018 13:39
If I remember correctly, each indicates the minimum dimensions, but it can be helpful to increase the length of the coupons so you can better hold the plates in a saw when cutting the bend specimens.
Parent - By Abdul Azeem Date 05-20-2018 10:35
Thanks.
