They are referring to the Authorized Inspector assuming the vessel is a code stamped unit. Look for a nameplate on the vessel that lists the manufacturer, date of manufacture, design temp and pressure, etc. If it is a code stamped vessel, you will see the appropriate ASME code stamp.
I am sure there is an AI if it is a code vessel.
