Maybe,if you found a collet big enough to hold a stick electrode it would work?
The real anwser is no,you need some shielding gas.Maybe use the stick setting to see if you like that.
like the other guy said, no...you won't even be able to heat up the material because the tungsten will vaporize faster than you can put it in the torch!
By Noel
Date 06-01-2003 04:56
Thanks. guys. That's all I needed to know.
