Up Topic Welding Industry / General Welding Discussion / repair butt joint with v groove
- - By joansaas28 Date 06-05-2018 19:53
Hi
I have a question, if i had a reparation in a butt joint with back plate, it joint has complete penetration, if i donĀ“t have drawings that specified the welded joint , Code D1.1 mentions something about the maximum dimensions for this joint?, the base material thicknessĀ“ is 8 mm
thank you
Parent - By welderbrent (*****) Date 06-05-2018 21:41
At least you gave us the applicable code.
But, what process are you using?
Are you using a Prequalified WPS?
What grade of material?
Is there a specific joint designation from Clause 3?
Is there more to your question to make sure we are clear on your query?
Brent
