Is the customer specifying AWS D1.1 for ship construction? If they are requiring AWS D1.1, are you using prequalified WPSs or are your WPSs qualified by testing, i.e., tensile testing, bend testing, etc.?
If you are using prequalified WPSs, follow clause 5 regarding post weld heat treatment and revised the existing WPS to include the PWHT to be used.
If the WPS is qualified by testing, a new WPS will have to be qualified using the PWHT required.
Good luck - Al
