Alan,
When we did this configuration in a shop that I worked in a few years ago, we welded the flanges on first because we could put those on a positioner or a manual roll out jig. You can roll those welds out pretty fast. Then you fit the 90's and make that weld in the 2G position. Not saying it's the only way or that there might not be something better now, but it worked for us. 100% volumetric test was required for the work we did.
