Up Topic Welding Industry / General Welding Discussion / emperical relation for deposition rate calculation
- - By j a c o b Date 06-29-2018 11:08
If I'm welding SAW, let's say I picked an electrode, as well as the current power and the voltage, the electrode extension as well as its diameter, the travel speed is known as well. is there any empirical relation that combine all of these inputs in order to give the deposition rate?
Thanks,
Jacob
Parent - - By jwright650 (*****) Date 06-29-2018 12:41
Jacob, all of that info is on your electrode manufacturer's data sheets. It is usually listed as pounds per hour. Although you should take in account for a small amount of waste(spatter, slag, etc), which is also on the data sheets.
Parent - By j a c o b Date 06-29-2018 15:50
Thank you sir
Parent - - By TimGary (****) Date 06-29-2018 14:43
Deposition rate formula -
WFS x Dia x Dia x Efficiency Factor x 13.33 = DR
WFS = Wire Feed Speed
Dia = electrode diameter
Efficiency Factor = Varies depending on electrode and transfer mode (SAW with solid wire should be .98)
13.33 = a formula constant for carbon steel
Parent - By j a c o b Date 06-29-2018 15:51
that's much appreciated, sir.
