Check the gap at the flywheel to magneto so you get a nice bright spark at the plug, check the float level in the carb to make sure it is set at the right height, check the pilot jet to make sure it is clear and not partially clogged.
Just a few things I could think of off the top of my head that could make it hard to start.
