Recently had a contractor request strain gauge monitoring, I've asked for help with this one as it is out of my comfort zone. No one local to me has had any experience with this, many have heard of it, but never actually seen it performed.
Anyone here have any experience of setting up and running the equipment? This particular case is rather unusual to me and I'm not familiar with how this monitoring will take place.
There have been micro-piles drilled all around this building (drilling and installing micro-piles I am very familiar with) and in the basement they are going to be installing balance beams consisting of anchor rods on each end of the beam and a rocker plate assembly at mid-span of the beam. So at each end of the beam, there will be a set of (2) 1.75" diameter anchor rods bolting the beam to a plate that is bolted to the top of the micro-pile hollow bar. We were asked to monitor the tensioning of these anchor rods to a target of 15k (min 10k, max 20k) using a strain gauge on the side of the anchor rods.
