Up Topic Welding Industry / General Welding Discussion / Welding Sequence Query
- - By keshav1987 (*) Date 08-29-2018 11:15
Please tell me if there is any thumb rule for Welding sequence , to avoid the Welding distortion .
Any way to reduce the distortion .
Parent - By Lawrence (*****) Date 08-29-2018 11:34
I keep these books on my desk.
John P Stewart  Distortion Control & Welder/Fitters Guide
https://johnstewartbooks.weebly.com/distortion-control.html
Parent - By TimGary (****) Date 08-29-2018 19:55
- - By ASHVIN Date 09-10-2018 11:50
Hi Guys,
i have purchased a YORK EASY WELD BW612. Generally this machine is connected to MIG welding machine. But latter from my supplier we came to know that we need to use 25% argon gas & 75% CO2 gas. we are using Decamig 7600 with CO2 GAS for our normal operation. Is this machine is suitable for using both type of gases as told above. Or if anybody know mig welding machine suitable to use these gases.
Any suggestion?
Parent - - By Tyrone (***) Date 09-10-2018 12:21
Hey Ashvin,
Welcome to the Original AWS Welding Forum.
In the future, start your own post, don't hijack someone else's.
To answer your question, GMAW machines don't know or care which shielding gas you use.  If your current process works, and you have all supporting documentation, why bother changing?
Tyrone
Parent - - By ASHVIN Date 09-14-2018 12:04
Hi tyrone,
thanks for your reply
can we use 25% of argon and 75% CO2 in Mig welding machine.
Parent - By 803056 (*****) Date 09-14-2018 12:25
For short circuiting transfer, yes.
