Up Topic Welding Industry / General Welding Discussion / Question about Structural Joint Numbering system
- - By wsrose Date 09-29-2018 18:09
B2V.3
Can anyone direct me to a chart that matches what the sequence number after the period stands for?
Fourth Character (Number) is assigned to sequence , 1,2,3 Etc... to cover distinctive joint differences such as bevel angle, root opening, with backing, without backing etc...
1?
2?
3?
T2V.2 = Tee joint - Welded both sides - Double beveled groove  ( but what is the .2?)
B2V.1 = Butt Joint - Welded both sides - Single V Groove  ( but what is the .1?)
B1V.1 = Butt Joint - Welded one side - Single V groove ( but what is the .1?)
Thank you!!!!
Parent - By SWN1158 (***) Date 10-02-2018 19:56
Try MIL-22-STD from the Department of Defense Design Criteria Manual for weld joint design.....
B butt joint
2 welded both sides
V bevel or v groove
. period used for separation
3 fourth character is assigned in sequence, 1, 2, 3, etc to cover distinctive joint differences such as bevel, angle, root opening, with backing, without backing, etc.
Try to google MIL-STD-22D-Navy BMR
It's in the "Forward" section, pg 3 of 81
