Up Topic Welding Industry / Technical Discussions / Please inquire the Welding terminology
- - By Material boy Date 11-27-2018 01:55
Dear. Expert
I was performing the numerical analysis for weld residual stress.
but, I don't konw the difference for mean between welding heat input(J/mm) and heat flux(J/mm3).
Could you tell me about that?
Accordingly, Please recommend the document and other paper for welding, residual stress(FEM)
Thank you :)
Parent - By Tyrone (***) Date 11-27-2018 15:51
Hey Material boy,
Welcome to the Original AWS Welding Forum.
Welding heat input should be expressed in J/min.
J/mm or J/mm3 is a force.
As far as FEM for residual stress, different software uses different techniques.  Choose your poison.
Tyrone
