Up Topic Welding Industry / Technical Discussions / Stainless steel welding defect
- - By Shmally Date 12-11-2018 14:50
Gentlemen ,
I have found by X-Ray so many weld defect such porosity and LOF between 7 to 9 clock position  in stainless steel piping
Thickness 4mm and I am looking to grind all the welding passes from7 to 9 clock position and re weld again root , inter , filling ,reinforcement pass .
My concern about the welding quality and how to maintain purging gas through half weld
Parent - By Shane Feder (****) Date 12-14-2018 23:34
Argon is heavier than air so you will have no problem purging in the 7 to 9 o'clock region.
Just ensure purge entry is at the lowest point and purge exit is at the highest and you should be fine.
