Up Topic Welding Industry / Technical Discussions / Solar 2127 welder question
- - By Monk1974 Date 12-13-2018 20:17
Hello. I recently got an older Solar 2127 wire feed mig welder. The question I have is can I reverse the polarity for flux core wire welding, and if so how?
I already had a look inside, still need to clean it out but didn't see any obvious places where you could switch wires for polarity. I'm assuming I would have to make my own leads and that this model wasn't meant for polarity switching.(I did find a post on here with the same topic but pictures describing a solution weren't hosted anymore)
Any ideas?
Parent - By jwright650 (*****) Date 12-13-2018 21:39
I'm thinking in your first picture, to switch the leads you will have to make up a short jumper to get the ground lead connected to the post that is connected to the gun. The lead currently connected to the gun looks like it will reach the grounding lug.
