Aluminum is hard! You need to keep practicing at it. You are using AC, right? It is very, very important to clean the aluminum thoroughly. Still, it is difficult, and the line between getting enough melt and blowing through is very fine.
I'll be interested to hear what other people say, as I suck at welding aluminum, too. I'm using an Invertec 205, and I know it is me not the machine as occasional welds have come out great.
Cheers,
Chris
put it on AC current, and around 100 amps, and the gas on 20 CFH. use pure tungsten, not the thoriated tungsten that you're using on mild steel and SS. i don't know what size it is in mm, but a .040" or 1/16" tungsten should be good. sharpen the tip and if while you're welding you see the tip ball up, that's good. if the tip looks like it's forming a drop like it's melting and falling off, the tungsten is too small. keep the tungsten as close to the joint as possible so the heat doesn't spread out and heat up a bigger area than you need. sometimes it's easier to learn how to weld aluminum on 1/8" (around 2.5 mm i believe) scrap pieces because it's more forgiving when it comes to burnthrough.
