Up Topic Welding Industry / General Welding Discussion / RSW energy consumption calculation
- - By Amrith_s Date 01-03-2019 20:57
Hi, does anyone know how to calculate the energy (in Watt-hours) of a resistance spot weld application?
What all information would I need to gather. I have the weld schedule, but I don't know how to convert that into power consumption.
Alternatively, is there a reliable method to measure it from the weld timer?
Parent - - By jwright650 (*****) Date 01-03-2019 21:38
If I'm thinking about this correctly.....amps x volts = watts; watts x hours = watt-hours
So....using round numbers for easy math: 1200amps x 30volts = 36000watts; 36000watts x 1 minute(1/60 = 0.01667hours) = 600watt-hours
So you need to know the amperage and voltage setting plus the amount of time(in hours) that the welding is taking place.
Parent - - By 803056 (*****) Date 01-04-2019 01:03
I don't claim to be an expert with resistance welders, but the voltage in the secondary is typically on the order of 5 volts +/-. The amperage is rather high and dependent on the nugget diameter and material thickness. The weld time is on the order of a fraction of a second. So the actual power per spot weld is relatively low.
There is a resistance welding handbook that may be helpful available from AWS.
Parent - - By jwright650 (*****) Date 01-04-2019 02:24
I forgot about the old AWS handbook manuals...I'll try to remember to look tomorrow when I get back to the office.
Parent - - By Amrith_s Date 01-04-2019 16:24
Thanks John.
Do weld transformers use single or 3 phase power?
My application is on the order of 150M spots per year, so even if it's small for one spot, it'll add up on that scale.
Parent - By jwright650 (*****) Date 01-04-2019 16:52
I think we may be talking about two different problems.
Are you trying to figure:
    -the kWatts-hours that will be consumed by the equipment on the primary side over the course of a year?(like shown on a power bill?)
or - the energy used on the secondary side to actually make the spot weld?
The transformers can be either single or 3Ph, I expect for large commercial type applications that 3Ph power would be the norm.
