Sloggy,
you can call Lincoln at 216-481-8100. Ask for Technical support. then hit 1, and 1 again (for engine driven welders). A service rep. will come on the line. You give them your serial/model# and what the machine is. (G8000) They should be able to help you troubleshoot the problem.
