I didn't even think about that possibility because I had electrode diameter on my mind, but you're correct... that it's referring to material diameter, i.e., pipe, which has limitations on welder qualification.
I know that a change in electrode diameter by > 1/32 is a PQR essential variable that would require a requalification of the WPS, but even if we were doing a PQR, that still wouldn't come into play, because the electrode diameter we're using for subsequent passes is a 1/32 increase.
This is something I've never had to deal with... using two different electrode diameters within the same joint, and I simply had electrode diameter on the brain. Thank you Lawrence! You da man!!!!!!!!!!!
