The welding symbol specifies the length of the fillet leg, no the throat. If the application involves a outside corner fillet weld that will be ground to some contour, i.e., ground to form a square corner, a standard welding symbol may not convey the necessary information. If that is the case, a sketch if the preferred method of providing the level of detail needed to ensure the welder understands what is needed.
