This may not be the correct place to post this, but I am working on laboratory scale testing and would like to find steel plate with the same chemistry as A-106B. A53B would also work. Any help would be greatly appreciated.
KirkFick, ASME Sec II part A is where you need to look. You can order it through IHS or ASME. Go to ASME or IHS's web site and you should be able to get it. It's about $760.00.
