Up Topic Welding Industry / General Welding Discussion / Standard Timing
- - By Himel Yusuf Date 01-27-2019 18:38
What is the standard timing for Electric Arc Welding in 1sq miter plain area (MS Metal of 8 mm thickness and for different plate and thickness)
Parent - - By Tyrone (***) Date 01-30-2019 12:55
You will have to explain what you mean by standard timing and how it relates to welding an area.  What does different plate and thickness have to do with it?  What electric arc process?
Lots of questions.
Tyrone
Parent - - By jwright650 (*****) Date 01-30-2019 13:06
I saw this question when it was posted and have the same questions about timing as it relates to welding plate of different thicknesses. Is this a robotic or resistance spot welding question?
Parent - - By Tyrone (***) Date 01-31-2019 12:18
The 1 sq. meter (?sp) really throws me a loop.
Parent - By jwright650 (*****) Date 01-31-2019 12:52
Same here
