That's a large tungsten, how many amps you at? Pure is good but has a harder start then say, 2% Lantinated and you don't ball that up. you also have to make sure that when you grind your tungsten, that you grind it longitudinaly, and leave a very small flat on the end, and it will naturaly get a little roundness to it but thats all. I don't know what kind of tungsten you are running, but my guess is that you are pretty hot for it to split.
