Up Topic Welding Industry / General Welding Discussion / Welding mild steel to 316 stainless steel
- - By Rick Way Date 04-02-2019 19:21
I have a client that wants to use 316 stainless to a mild steel hinge for a gate. I am having trouble locating information regarding making this weld. What is the recommended process/electrode for this weld. As a heads up, I am unsure of the weld process the fabricator will use for this connection.
Any recommendations? Sorry if this is a repeat question, I couldn't find much information on the topic at hand pertaining to my conditions.
Parent - - By 803056 (*****) Date 04-02-2019 19:27
Type 309 is usually the filler metal used for welds joining carbon steel to austenitic steel.
Parent - - By Rick Way Date 04-02-2019 20:50
Thanks Al,
I knew that 309 was typically used for 304 grade stainless, I just wanted to make sure there wasn't a sufficient difference in metallurgy that would prevent a suitable weld from being made between the 316 grade and mild steel.
Parent - By WeldinFool (**) Date 04-03-2019 18:26
Umm, no; 308 filler metal is used to weld 304 stainless, not 309. And as Al said, 309 is typically what is used to weld carbon to stainless steel.
