Hi John
Yes there is some language on reinforcement.
8.4 Throat and Convexity of Fillet Welds. The minimum throat shall be as specified for the application with maximum
convexity not to exceed 1/8 in [3 mm] (see 1.1.3).
1.1.3 This code requires values to be specified by the Engineer for weld type, size, and location of the application. See
subclauses 8.2, 8.4, 13.1, and 13.3.
