Interssting question,
I do hawever wonder how CVN is applicable to a joint that has a notch at the root......
I think form a CVN perspective if the composition and heat input is comparable then it should be trasnferrable, I have personnally never performed a CVN on a single pass.
For further evaluation of criticallity what is the material MDMT in applicaiton, what is the design conditions, cyclic or static.
I see absolutely no value in performing a CVN test on single pass and you have to end up using an emprical conversion fo ra subzise specimen.
I might be wrong......
