I have always found that the best way to combat this weld sagging and undercut is to direct the weld mostly toward the vertical piece, not the horizontal. Also the gun or electrode angle in relation to the vertical piece needs to be at or just below 90 degrees. This helps to force the molten puddle to stay in the crater dug by the arc, rather than sagging and undercutting.
Tim
Dave,
To qualify my comments here, I am not a TIG welder (my career path just never went that way yet). So I don't know for sure if a 45 deg angle is best for TIG. But if you're dealing with SMAW, FCAW, or SAW, you'll find it works very well.
Placing your materials at a 45 deg angle gives you a true 1F fillet weld, and grooves are similar. If your heat (amps/volts) is correct for the amount of filler metal being added, you should have very little undercut (due to surface tension of the molten metal, you will nearly always have some undercut but it can be almost too small to realistically measure).
In fact, that is a technique used to increase productivity, whenever we find it practical. The position allows us to turn up the power and lay in a lot of metal while gravity helps shape the weld face. You do have to be sure to stay on the leading edge of the puddle to avoid slag and metal from rolling ahead; that would hinder penetration and promote slag entrapment.
I imagine TIG would be similar, but this is where someone else should jump in and explain the finer points.
Chet Guilford
Dave,
To produce a undercut free fillet weld in the horizontal (2F) position it is important to have the proper amperage for the thickness of the base material. The GTAW torch angle, travel speed, and technique are essential as well. Please try the following:
a) Torch angle 45 degrees - this will apply an equal amount of heat into the horizontal and vertical member of the T-joint.
b) Grind tungsten electrode to a point with the grinding marks in line with the electrode - a contaminated tungsten will direct the arc force in most cases to the vertical member resulting in uncontrollable undercut. If the electrode becomes contaminated, stop welding grind a new point. As you grind Dave you will be able to see by the sparks when the electrode is clean and ready to continue the weldment.
c) Welding Technique - walking the cup or free handing - which ever you choose, keep the weave motion to a minimum. If you weave to wide, undercut will occur.
d) Adding filler metal to the puddle - dip the filler into the puddle or place the filler rod into the joint and melt into the puddle.
e) Choose the proper diameter ceramic cup - to large for the application will cause difficulty viewing the puddle.
f) Tungsten electrode stickout - the general rule of thumb is to have the electrode out past the face of the ceramic cup no longer than the inside diameter of the cup.
I hope these comments are helpful, and have a great 4th of July weekend! Jinx 67'-68'
If you're getting undercut with TIG, you're either too hot or using too small of filler. And from personal experience, you never need to weave using TIG. If you need a bigger fillet for strength, use a different process.
