Well ,we did a PMI on the material and my procedure has the choice of rod I want and also the pre heat and post weld heat-treat procedure on it, that is a mandatory requirement per B31.3. The reason we are cutting out only one half of the pipe at a time is the problems I foresee in refitting that big boy "it`s only a 6" weld but it`s a reducer 6"x10" and on the other side of the valve we are welding to it`s a 14"x6" reducer",before we cut and bevel the cracked side, the line will be supported in all directions,there could be major stress on that line. The plant reliability engineer will get a boat sample out of the weld for testing to see if we can determine the cause of the crack. The PMI did reveal a low content of chrome, less than 1%, indicating possibly the wrong rod was used, 70-series maybe. So that`s why the choice of ER90SB3 was chossen over the lower chrome content ER80SB2. I was mainly concerned about the rod choice, I did hear mention from another inspector about using NICRO-3FE-1. Have you heard of useing this filler material on this type weld, I sure haven`t. By the way, the biggest gap I have welded for RT was 7/8" on bottom 1/4" on top 14"carbon pipe in a tight spot, left handed on one side and right handed on the other looking through the gap feeding the rod from the top quarter. I DON`T MISS THOSE DAYS.
