There is something you have to understand, before and while the welding progress, you or your welder clean the surface with brush and see the result all passes. And also choose the right consumable wire, I know it is a very expensive method, but, in long term it is very useful. Afterthat, acc. to material, you prefer to choose pre-heat temperature and interpass temperature. This application is for Heat affected zone area, when the welding progress continues, form of the sheet metal stays to stabilize toughness and material features.
Choose and prepare the rightful pWPS, and See the result in PQR requirements.
Best Regards.
Design Codes and Standards detail minimum requirements.
Weld on weld is a common practice in welding that is not detrimental in all but extreme cases.
Standard Code requirements for controlling how much weld may be placed in a single joint or connection are weld size tolerances, heat input limits when impact requirements apply, and requirements for WPS controlled repair procedures.
At any time "The Engineer" wishes to exceed minimum Code requirements, they may do so, in any way they choose, through additional project specifications. However, these requirements are to be detailed at the beginning of a project, or before the job bidding process.
Additional requirements may be applied to a project that is already underway, but this means the Contractor(s) can submit Change Orders to cover unplanned expenses, or internal changes need to provide increased cost justifications.
Many Contractors rely on this to profit from jobs, as they submit an initial low bid to get the work, then charge a premium for change orders.
Tim
