Hello All
For any one doing work to CSA W59 / CSA W47.1, here is a data sheet for welding rebar to structural steel.
If submitted to the CWB for approval, it should pass based on previous test accumulated by the CWB.
You cannot weld rebar to rebar., only rebar to structural steel. The grade of rebar is 400W. This is a weldable grade of rebar.
Be sure to read the notes at the bottom left of the page.
Thanks for your time.
welderfitter
