Hi all, I am your average Joe determined to learn how to weld. I was wondering if anybody out there has ever had an issue with running a 3PH inverter MMA welder with a rotary phase converter (RPC)? I have a 13.5 HP/19 Amp 240v single PH to 415v 3PH RPC and a Kemmpi MLS2500 inverter welder. When connected, the welder turns on but it doesn't want to ARC?, The Kemmpi's specs are 3PH, 400v +20%/-15%, 10A with a kVA between 7.7 - 9 kVA.
So far I'm at a loss as to why it's not working?
Regarding troubleshooting so far I have:
1/. Swapped all the phases but no chocolates.
2/. Taken the welder to a mates Factory to confirm the welder is working (which it is! Perfectly!)
3/. measured the volts between phases:
L1 - L3 = 416V
L2 - L3 = 434V
L1 - L2 = 458V
I am thinking of a few possible problems;
a/. Maybe the tolerance between phases are too far apart?
b/. Maybe the welder is having trouble processing the input power signal from the RPC?
c/. Amps??
Anyway, If anyone has had similar experiences, or any switched on members out there have an idea, I'd love to know your thoughts or how you overcame it.
Thanks for reading
